Getting a lot of warnings when compiling to Hex, The code works OK
Any idea why ?
Atmega128 Compile warnings
Alan_37
- Has thanked: 57 times
- Been thanked: 28 times
- ATmega128A.fcfx
- (25.9 KiB) Downloaded 313 times
- ATmega128A.msg.txt
- (20.36 KiB) Downloaded 323 times
- Has thanked: 616 times
- Been thanked: 815 times
Re: Atmega128 Compile warnings
We mark variables as volatile so that they work correctly when manipulated inside an interrupt. Some functions do not accept volatile variables so the volatile cast is simply removed and hence the warning. Should be safe to ignore. I'll see if it's something we can potentially hide from the compiler output.
Hi BenR
Thanks for your reply
where sould I put the -w flag to ignore warnings, the problem is a lot of warnings
mixing with errors and it's making it difficult to spot and fix the errors.
OK Found it
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat
LIne 13 : add -w after -Os
"%MX_COMPILER%bin\avr-gcc.exe" -mmcu=%MX_CHIP% -Os -w -ffunction-sections -fdata-sections -funsigned-char -o %MX_ELF% %MX_SOURCE% -lm -Wl,-gc-sections
Now compiles much faster
