Hi everyone,
I'm trying to create a flowchart in Flowcode 10 that works according to the "3. EEPROM read and write V3" flowchart, but it doesn't work. Please help me.
All the best!
I2C test
samtin
- Has thanked: 12 times
- Been thanked: 6 times
I2C test
- test eeprom.fcfx
- (19.6 KiB) Downloaded 501 times
- (view online)
- I2C test.jpg (64.49 KiB) Viewed 13087 times
- Has thanked: 246 times
- Been thanked: 258 times
Re: I2C test
Hi Samtin
You can test with the component from Flowcode
search for "24LC512" and drag and trop it.
This is comfortable to use.
- 2024-09-30_16-34-40.PNG (51.19 KiB) Viewed 13053 times
Re: I2C test
Hi Stefan,
I tried and it gives an error, below is the Flowcode message:
Microchip MPLAB XC8 C Compiler V2.10
Build date: Jul 30 2019
Part Support Version: 2.10
Copyright (C) 2019 Microchip Technology Inc.
test eeprom copy.c: 519: (1250) could not find space (130 bytes) for variable _FCL_BUFF
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
Autoclose turned off
FINISHED
I am using PIC16F877A.
FINISHED
- Has thanked: 177 times
- Been thanked: 1027 times
Re: I2C test
This is a continuation from the old forum. The MCU doesn't have enough RAM for the component to work.
See https://www.flowcode.co.uk/mmforums/vie ... 62#p108662
If I get a chance this evening I'll try making a 'sawn-off' version of the component without the Write/Read page functions.
Re: I2C test
It seems that there is no more activity on the old forum, but there it was discussed and developed program sequences for I2C and eeprom, both of which interest me, to be able to use Flowcode 10 for both I2C and eeprom. To create or modify a component, I have already begun to study and understand how to proceed for a good result so that in the future I can create a component for flowcode, I am aware that this will take some time, that is why I am asking for help from those who have enough experience and who plays with something like that. Whenever you can, help me to make the presented flowchart work.
Re: I2C test
Yes - definitely a more lively forum here.
Cut the component down to it's bare minimum. Read and Write. It should compile - and I've tested on an Arduino and it works there...
To install:
1) Save the .fcpx file to a directory - point FC at this in Build->Customise->Locations->Search for components in. Close and re-open FC.
2) Search for the component (it's called EEPROM (24LC5212) Minimal)
3) Use Read and Write. Note that i2c requires pull-up resistors on SDA and SCL
You'll need to add some code to display the values. Let us know how it goes
I probably should have renamed the component source code ?
To install:
- eeprom512_min.fcpx
- (4.33 KiB) Downloaded 504 times
- eeprom(1).fcfx
- (9.4 KiB) Downloaded 511 times
- (view online)
- FC_Comp_Source_Serial_EEPROM_(24LC512).fcfx
- (30.56 KiB) Downloaded 520 times
- (view online)
Re: I2C test
First of all, I have to thank you for your help. This time it compiled, but it doesn't store, it seems, because it displays 255. In Flowcode it simulates correctly, but it also simulates correctly with the Flowcode component unmodified, only it doesn't compile. Always the pull-up resistors are connected, I also pay great attention to the connections between the microcontroller and other components such as this eeprom.
- fc.png (217.64 KiB) Viewed 12972 times
- eep_min.jpg (73.79 KiB) Viewed 12972 times
Re: I2C test
Odd, it is just the component - I've not modified it, just deleted the page functions...
Do you have a logic analyser - take a look at what is on the i2c.
You don't have the 'protect' pin pulled high by mistake?
