I2C test
samtin
Has thanked: 12 times
Been thanked: 6 times
Re: I2C test
Post by samtin »
A0, A1, A2 and WP to gnd, SCL to RC3 and SDA to RC4 with pull-up resistors (4.7K)
Has thanked: 177 times
Been thanked: 1027 times
Re: I2C test
Post by mnfisher »
Although it might not be writing the data correctly - it is also possible that Read isn't working (or display!)
Can you upload the chart you are using to test....
samtin
Re: I2C test
Post by samtin »
Of course, I have attached the flowchart below.
test eeprom (2).fcfx
(18.48 KiB) Downloaded 423 times
Re: I2C test
Post by mnfisher »
One thought - 255 is the value of an 'empty' byte.
Don't have much time today but will try with a PIC and a logic analyser. Other thoughts - is the display i2c as well. (I'm just looking at the code on my phone using the online viewer)
Could you try another 'output' method (flash an Led n times) just in case there is a conflict - but clutching at straws a bit.
I don't have the same pic but a logic analyser is the only way to see what is really going on.
samtin
Re: I2C test
Post by samtin »
The display is not I2C, only the eeprom.
Re: I2C test
Post by mnfisher »
I set up a PIC16LF15313 with a SSD1306 i2c (128 * 64) display. This PIC only has 256 bytes RAM - so I used my minimal ssd1306 component (see viewtopic.php?t=2742&hilit=ssd1306&start=40 ) otherwise no chance....
I also attached a logic analyser - and with i2c set to hardware mode - nothing on SDA and SCL. Changing to software mode and there is life.
Oddly for writing 0 .. 9 I got on the display 0 r 2 t 4 v 6 x 8 z (and I used .x = Read(.i) Print(.x + '0', .i * 10, 2) So- not sure quite what is happening on the odd numbers. I couldn't use PrintNumber - insufficient RAM!
So - try software mode on the i2c. It might just do the trick?
Rather a rats nest - with PICKit and logic analyser attached. The oscilloscope is 'underneath' the breadboard - and there are some bits from my dfplayer tester to the right. Display is also not very bright (it's rather old) - I print some text ("2345") to prove it can display odd numbers - next line is the first 10 bytes read from EEPROM. The PIC is at the left - eeprom in the middle, with the i2c daisy-chained from a1 and a2 (the display and EEPROM have different addresses, so this is okay).
I modified slightly - and printed the address in row 2 and data in row 4 - and row 2 is correct (0 1 2 3...) but the data still has the odd characters (though there is a pattern - they are not random)
Will have another look tomorrow.
Re: I2C test
Post by mnfisher »
It's very odd - looking with the oscilloscope - the write looks correct, as does the read. However whereas for the even addresses it returns the correct data, for the odd addresses it doesn't (for example address 1 returns 0x42)
Very strange. Here is the trace showing the write to address 1, followed by the trace showing read of address 2 then address 1 :-(
Anyone any idea what's going on?
Re: I2C test
Post by mnfisher »
So after a bit of fiddling - I went back to an old version of the 24LC256 component I did a while ago.
Now up and running smoothly in software mode (hardware mode doesn't seem to be supported?) :-)
In a simple demo - it writes 10 bytes (1,2,3 .. 0) to the eeprom then repeatedly reads back the first 5 bytes - shown here on the scope trace.
Note that the component works slightly differently to the FC one - the user sets a read and/or write address using StartRead and StartWrite - then they can read or write single or multiple bytes using ReadData and WriteData - and these automatically increment the address to use.
eeprom_mnf.fcfx
(9.47 KiB) Downloaded 426 times
eeprom_24lc256.fcpx
(3.12 KiB) Downloaded 430 times
eeprom.fcfx
(22.04 KiB) Downloaded 390 times
samtin
Re: I2C test
Post by samtin »
Hi everyone,
Forgive my absence, I'm back and I also have to thank you very much Martin for your help and for your effort to do good.
Re: I2C test
Post by mnfisher »
Welcome back - and hopefully been of some assistance...
