DS3231 ALARM
kaqkk007
Has thanked: 4 times
Been thanked: 4 times
Re: DS3231 ALARM
Post by kaqkk007 »
Lately the DS3231 handling on pic bases has been getting worse , I had to change the settings many times before it would work . Today even resetting the update version does not help , it refuses to work . What could be the cause ??
kaqkk007
Re: DS3231 ALARM
Post by kaqkk007 »
I noticed that only pic16f628 won't start (with internal oscillator)
Has thanked: 442 times
Been thanked: 661 times
Re: DS3231 ALARM
Post by chipfryer27 »
You need to include your chart illustrating the problem before we can assist.
kaqkk007
Re: DS3231 ALARM
Post by kaqkk007 »
This is the problem that is not communicating with the RTC.
7segm_SANYI20241207.fcfx
project
(28.7 KiB) Downloaded 508 times
kaqkk007
Re: DS3231 ALARM
Post by kaqkk007 »
Perfect in simulation but returns 0000 values "live"
kaqkk007
Re: DS3231 ALARM
Post by kaqkk007 »
The even values of the run variable are displayed ( BCD converter 74141 + digit outputs ) the odd ones are blanked ( 15 values and digit = 0 )
Re: DS3231 ALARM
In your settings you have the clock set as RC Clockout not internal oscillator. Remember if using internal oscillator to include a c-code block at the very beginning of your chart to set the registers. The IntOsc Helper component will assist in creating the value.
kaqkk007
Re: DS3231 ALARM
Post by kaqkk007 »
Thank you I will try it
Re: DS3231 ALARM
The attached sets the internal oscillator to 4MHz
IntOsc.fcfx
(7.72 KiB) Downloaded 480 times
kaqkk007
Re: DS3231 ALARM
Post by kaqkk007 »
Started thanks for your help
