PIC18F67K40 UART Send String
LeighM
Has thanked: 110 times
Been thanked: 302 times
Re: PIC18F67K40 UART Send String
Post by LeighM »
Add a "C" icon at the start of your program, and paste this code into it ...
asm ("BSF NVMCON1, 7");
seokgi
Has thanked: 8 times
Been thanked: 9 times
Post by seokgi »
I have additional questions.
I am using CircularBuffer. If there is data called "kg" among RS-232 input data, it means to move on to the next processing.
It worked well because I programmed the same code on another MCU. However, in the PIC18F67K40, the data "kg" is not found.
I think I'm doing something wrong, so please advise.
LeighM
Post by LeighM »
Add the C code and hopefully all will be well.
The silicon error in the PIC18F67K40 is causing the compiler generated code to not be able to access any strings in your code.
seokgi
Post by seokgi »
All problems have been solved. CircularBuffer works fine and UART SendString works fine too.
Thank you very much.
