Hi.
I use the PIC18F67K40 to use multiple UARTs. But SendNumber works, but SendString doesn't work.
I don't think I'm wrong because it's a function I use every time.
Please take a look at this Send String function.
PIC18F67K40 UART Send String
seokgi
- Has thanked: 8 times
- Been thanked: 8 times
Re: PIC18F67K40 UART Send String
It's my flowchart.
- 2F2f_EVA-18F67K40.fcfx
- (60.36 KiB) Downloaded 610 times
- Has thanked: 616 times
- Been thanked: 814 times
That all looks ok.
In your config settings you have the watchdog timer and the LVP enabled, I would disable both of these settings.
If it's still not working after doing changing the config then maybe try assigning the string data into a variable and passing the variable to the SendString function and see if that works.
Let us know how you get on.
That all looks ok.
