PIC18F67K40 UART Send String
seokgi
Has thanked: 8 times
Been thanked: 8 times
Post by seokgi »
Hi.
I use the PIC18F67K40 to use multiple UARTs. But SendNumber works, but SendString doesn't work.
I don't think I'm wrong because it's a function I use every time.
Please take a look at this Send String function.
Has thanked: 163 times
Been thanked: 960 times
Re: PIC18F67K40 UART Send String
Post by mnfisher »
That would be very odd - SendNumber just converts the number to a string then uses SendString....
Can you post your code?
seokgi
Post by seokgi »
It's my flowchart.
2F2f_EVA-18F67K40.fcfx
(60.36 KiB) Downloaded 611 times
Has thanked: 616 times
Been thanked: 814 times
That all looks ok.
In your config settings you have the watchdog timer and the LVP enabled, I would disable both of these settings.
If it's still not working after doing changing the config then maybe try assigning the string data into a variable and passing the variable to the SendString function and see if that works.
Let us know how you get on.
seokgi
Post by seokgi »
As advised, I changed the settings and sent a text through a text variable, but SendString does not work.
seokgi
Post by seokgi »
It's not working.
Please Help me.!
LeighM
Has thanked: 103 times
Been thanked: 302 times
Post by LeighM »
seokgi
Post by seokgi »
Thanks for the reply.
But that document doesn't work for me.
I asked the question that UART TX signal does not become SendString.
Is there anything I don't understand?
LeighM
Post by LeighM »
Did you try the ASM code in a C icon at the start of your program?
seokgi
Post by seokgi »
Sorry. I can't use c or asm. How do I add it?
