Here is a Simple fcfx file I made just to show the bug, this compiles ok on V7 but not on V9 maybe we can fix this .
WS2812 Build Error ( STM32F407ZG )
Alan_37
- Has thanked: 57 times
- Been thanked: 28 times
- Flowcode1.msg.txt
- (84.57 KiB) Downloaded 913 times
- Flowcode1.fcfx
- (9.64 KiB) Downloaded 802 times
- Has thanked: 590 times
- Been thanked: 778 times
Re: WS2812 Build Error ( STM32F407ZG )
Thanks for letting us know, hopefully should be fixed for you now.
I am happy to read that the compilation is done correctly but my question is: is the led lighting correctly?
As quoted in the FlowcodeV7 forum: https://www.flowcode.co.uk/mmforums/view ... 76&t=22045
With an ECIO40 and an ECIO40P16, compilation is performed without warning.
With a 16F887A clocked at 19.6608MHz, the same warning reappears :
Is it a problem of frequency of work?
Bruno
With these 3 targets, the high and low state times for the two logic states do not comply with the WS2812B protocol and the Led lights up in white.#warning WS2811 Timings are less than 10 instructions, timing may be incorrect at the current clock speed
^ (162) #warning: WS2811 Timings are less than 10 instructions, timing may be incorrect at the current clock speed (warning)
Bruno
Hi , on V9 it is compiling and working ok , though I once notice that yes at first it lights up white then after the second refresh it starts to work correctly , could be that there are still bugs
Thank to you Alan,
Did you check the timing on the command output with multiple leds in cascade or a RGB LED strip? I am curious to know the result if you have the material ...
Bruno
Bruno
I beleive should be fixed in v8 now. Do you need it for v7 also?
