Scada
nickchlapout
Scada
Post by nickchlapout »
Hello I was about to upload the scada firmware to my arduino when I ran into this
I hope you can help me
Screenshot 2021-03-28 181407.png (26.01 KiB) Viewed 5230 times
Screenshot 2021-03-28 181337.png (183.51 KiB) Viewed 5230 times
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: Scada
Post by p.erasmus »
It looks like there are a few things missing in the file you have
I just last week programmed a UNO with this file you can try it make sure you select the Correct comport for your Board in the Properties
Arduino_Uno_SCADA_Firmware.zip
(21.21 KiB) Downloaded 599 times
Included is the hex file you can program your UNO with Xloader and this hex file
Just compiled the file again ,make sure you are using the Firmware FC chart
Has thanked: 616 times
Been thanked: 814 times
Re: Scada
The I2C Master and UART components require one of the comms packs.
You could instead use something like Xloader to load the pre-built .hex file onto your Arduino and then everything should work correctly without having to compile the code.
nickchlapout
Re: Scada
I purchased all the comm packs but it seems Like my flowcode hasn't been update, altough it shows me like it has been(in the license key)
Re: Scada
You will need to re enter your username and password to refresh your license in Flowcode.
