ESP32 4Bit SD-Mode Init problem
Has thanked: 246 times
Been thanked: 257 times
I get a problem to compile to hex When I'm use the the 4Bit SD-Mode Init command
Normally this works without a problem with the 4Bit SD-Mode Init command of the card.
I do the same as with the other programs. But this one don't compile. I have already tried many things
C:/Users/stefan.erni/Desktop/esp-idf-2/mtxesp32s_sdkconfig/main/esp-project.c:277:21: error: implicit declaration of function 'FC_CAL_FILE_ReadByteFromFile_2' [-Werror=implicit-function-declaration]
  277 |     if (FCL_DATA_BYTE == 0)
Test_SD_post_new.fcfx
(20.26 KiB) Downloaded 345 times
Has thanked: 792 times
Been thanked: 850 times
Re: ESP32 4Bit SD-Mode Init problem
Hi Stefan.
Test_SD_post_new.fcfx compiles for me OK.
Have you got all the latest full library updates?
Hi Martin
Very good that it works for you.
I changed the menu config and now it works again.
I test far and append string works perfect.
I still have problems with writing the sector.
The file remains empty.
(46.45 KiB) Downloaded 333 times
Hi Stefan, thank you.
I have added the bug to bugs list.
It will be sorted ASAP
Hi Martin
Thank you,
First the good news. I have done several 12 hour long tests, saved continuously, and have not a single problem.
But a few commands don't seem to work properly yet
- local array append give problems to compile, you can see when you activate them in the macro, but with global array it compiles.
- AppendByteArray is appending just one letter
Would it be possible to make the change to the next sector much faster?
(50.6 KiB) Downloaded 338 times
Hi Martin
There is still a small problem. I use the option long filename support. This option must also be selected in the menu. If this is not done, my test will not work for you. I have changed the longname to a short in the test program.
program with shortname:
Test_SD_post_ShortName.fcfx
(50.38 KiB) Downloaded 352 times
with shortname:
program with longname need a change in menue:
Hi Stefan.
My plan is I will be looking into this tomorrow.
Hi Martin
I downloaded the component from the Flowcode website and looked at it.
But this is probably an old version. Can you please give me the current version?
Hi Martin
I have looked at the component and WriteByteToBuffer, ReadFileLength do not work and are perhaps not yet implemented,
or I still don't understand exactly how it works.
During the test I did not notice any difference if I change the clock from 20MHz to 40Mhz.
Also no difference if I choose 4bit or 1bit mode. Both equally fast
from component WriteByteToBuffer:
from component ReadFileLength:
Hi Martin
Some news about the sd-card problem?
