MPU-6050 NOT WORK IN HARWARE
SILVESTROS
Has thanked: 32 times
Been thanked: 2 times
Post by SILVESTROS »
Hello to all!
I was connected a MPU-6050 accel./gyro module to a PIC18f46k22 , and send data to PC with UART. In simulation I get data normally , but in hardware I get zeros..Is the issue in MPU6050 component ?. If so, Is there an update at component that solve the issue ?
Many thanks
Basl
Has thanked: 772 times
Been thanked: 833 times
Re: MPU-6050 NOT WORK IN HARWARE
Hello, Basl.
Do you have a logic analyser?
If so, when the MPU6050 is reading the Who an I register at = 117 (0x75) what is the result returned?
The read is performed at the very start.
SILVESTROS
Hello medelec35 !
No , I have not logic analyser , only oscilloscope...can I test the WHO AM I register with I2C macro ( Master) with FC10? ...Generally the issue is from component or hardware ?.. Have been tested the MPU-6050 component in hardware ?
Basil
Hi Basil.
The issue could be that you have a fake device.
For some reason the Who am I register is set to 0x98 instead of 0x68
As the Flowcode component is looking for 0x68 within the Who am I register, the hardware wont work until 0x68 is retrieved.
If not got an analyser then as a temp method, I can change the Who am I expected value from 0x68 to 0x98.
If that does not work then I can temp remove the who and I detection.
However, you will need to bare in mind that if the chip is fake, then will the rest of the code work as expected?
Attached is the who am I register read set to 0x98.
%ProgramData%\MatrixTSL\FlowcodeV10\Components
Place the attached component.
MPU6050.fcpx
(5.83 KiB) Downloaded 301 times
Has thanked: 177 times
Been thanked: 1016 times
Post by mnfisher »
It might be a ICM-20689 - which looks to be 'marketed' as a MPU-6050A on some Chinese boards - this has 0x98 as the 'whoami' value (at the same address) - but isn't compatible code wise (register addresses are different)
The MPU-6050 was discontinued some time ago (replaced by the ICM-20689) - so although it might be counterfeit, it might actually work (but probably not with the MPU-6050) code...
See (for example) https://forum.arduino.cc/t/mpu-6050-a-m ... 050/861956
Thanks Martin.
On reading what's in the link, I agree.
I will create an ICM-20689 component.
Has thanked: 245 times
Been thanked: 257 times
Hi to All
A question to Basl
Are you using the Senser on a small board?
for the new component, maybe I can help with testing.
There is a good overview of the TDK sensors. Which type and specifications
https://invensense.tdk.com/products/mot ... ng/6-axis/
but which is the current sensor ?
I have created an ICM20689 for you to try.
Can you use that instead of the MPU-6050 component.
ICM20689.fcpx
(5.85 KiB) Downloaded 287 times
