PIC16F1455 not work PWM
alekseyvorobev1
Post by alekseyvorobev1 »
pic16f1455
hi, trying to use PVM on timers 1 and 2 results in a compilation error
Снимок экрана 2025-02-14 231508.png (243.09 KiB) Viewed 4291 times
Снимок экрана 2025-02-14 231438.png (243.08 KiB) Viewed 4291 times
Has thanked: 795 times
Been thanked: 858 times
Re: PIC16F1455 not work PWM
Thank you for reporting this issue.
I will investigate and fix the cause of compile failure.
Hello the issue has now been corrected.
Hopefully the updates will be available soon.
When you update your component database, just change Files-in-use to Full database.
