DS3231 ALARM
kaqkk007
Has thanked: 4 times
Been thanked: 2 times
Re: DS3231 ALARM
Post by kaqkk007 »
Just one question : do you plan to include the aging offset setting in the componens ? (a more inaccurate rtc will be released )
claudemir
Has thanked: 2 times
Re: DS3231 ALARM
Post by claudemir »
Sim, preciso preciso desse rtc, para cronometrar as horas e salva los toda vez que tenho perca de energia
Vai ser lançado na versão 9?
kaqkk007
Re: DS3231 ALARM
Post by kaqkk007 »
I think it's been in the program for a long time (I used it in 6) look for it in storage
max.tisc
Been thanked: 12 times
Re: DS3231 ALARM
Post by max.tisc »
hi, why the alarm settings were not implemented on the DS3231 in the FC10 version? I tried to load the component made for the FC9 but FC10 does not see the new component loaded.
thanks
kaqkk007
Re: DS3231 ALARM
Post by kaqkk007 »
I put the fcpx file I found here into the library but when I want to use it there is no option for pin settings so I tried to use it with the "old" rtc, but the 2 separate rtcs don't like each other. How can I read and write a register in the rtc? osc enable aging offset. Pic 18f252 ...
