Components not loadable / BMP280 no values
Jorg_Guldner
Been thanked: 4 times
Re: Components not loadable / BMP280 no values
Post by Jorg_Guldner »
thanks for clearing all around the BMP280.
Jorg
Viktor74
Has thanked: 5 times
Post by Viktor74 »
HI. Cannot read BMP280 pressure, what is the problem?
Has thanked: 756 times
Been thanked: 819 times
Hello, You have not attached your project file.
We can't help you until you do.
Viktor74
Post by Viktor74 »
HI I'm sorry, I am adding files, maybe I'm doing something wrong?
BMP_280.fcfx
(13.19 KiB) Downloaded 192 times
Thank you for your project file.
Simulation of your project is working for me.
BMP280 Pressure sim.png (38.69 KiB) Viewed 6527 times
I would recommend doing a full component update
Help > Library Updates...
Change Files in-use to Full database.
Then reload your project and try again.
Viktor74
Post by Viktor74 »
Hi Martin. I updated the library and now everything works great, thank you very much! ;)
That's great!
You're welcome and thanks for letting me know.
Viktor74
Post by Viktor74 »
Hi Martin. A little off topic but I thought I'd ask, I have a BME280 sensor on the same board with an ENS160 air quality sensor. The BME280 works fine and reproduces all the parameters, but the ENS160 is not connected. Could you help me in any way? Or maybe you already have such a macro for ENS160? I want to use the entire module of 2 sensors. I have written a small program (but only in Ukrainian) that works with BME280, but it lacks ENS160. Thank you very much for your understanding!
Hi Victor,
The image you have shared that shows the BME280 looks amazing!
As for the ENS160 , you will need to request it here
Viktor74
Post by Viktor74 »
Martin such a register is also written to the database and draws a graph. I tried to find information about the macro for the ENS160 on the forum, but it was not successful, unfortunately, it was all to no avail. Maybe I'm doing something wrong in the forum search.
