thanks for clearing all around the BMP280.
Jorg
Components not loadable / BMP280 no values
Jorg_Guldner
- Been thanked: 4 times
Re: Components not loadable / BMP280 no values
HI I'm sorry, I am adding files, maybe I'm doing something wrong?
- BMP_280.fcfx
- (13.19 KiB) Downloaded 193 times
- BMP280.png (267.04 KiB) Viewed 6552 times
- Has thanked: 757 times
- Been thanked: 819 times
Thank you for your project file.
Simulation of your project is working for me. I would recommend doing a full component update
Help > Library Updates...
Change Files in-use to Full database.
Then reload your project and try again.
Hi Martin. A little off topic but I thought I'd ask, I have a BME280 sensor on the same board with an ENS160 air quality sensor. The BME280 works fine and reproduces all the parameters, but the ENS160 is not connected. Could you help me in any way? Or maybe you already have such a macro for ENS160? I want to use the entire module of 2 sensors. I have written a small program (but only in Ukrainian) that works with BME280, but it lacks ENS160. Thank you very much for your understanding!
- Prog.jpg (189.31 KiB) Viewed 4861 times
- BME280_ENS160.jpg (52.73 KiB) Viewed 4861 times
Hi Victor,
The image you have shared that shows the BME280 looks amazing!
As for the ENS160 , you will need to request it here
Martin such a register is also written to the database and draws a graph. I tried to find information about the macro for the ENS160 on the forum, but it was not successful, unfortunately, it was all to no avail. Maybe I'm doing something wrong in the forum search.
- Prog_1.jpg (135.67 KiB) Viewed 4768 times
