WS2811
TheShadowOfTriumph
Flowcode v10 WS2811
Post by TheShadowOfTriumph »
This component stop working after update in February. Settings are can`t change anything.
TheShadowOfTriumph
Re: WS2811
Seriously, guys, this component I'm using not for toy application! May you write any response?
Has thanked: 478 times
Been thanked: 713 times
Re: WS2811
Post by chipfryer27 »
Could you explain what you mean by "Settings are can`t change anything." or perhaps attach a chart showing your issue?
Has thanked: 311 times
Been thanked: 479 times
Re: WS2811
Sorry. It looks like we have overlooked this. We'll investigate and report back asap.
In the meantime, you can revert to an earlier working version of the component using the library updates panel.
TheShadowOfTriumph
Re: WS2811
Unfortunately, when changing the component version to 5, I see this.
Has thanked: 794 times
Been thanked: 858 times
Re: WS2811
Can you attach your .fcfx project file that has stopped working.
Also the .c code as well.
TheShadowOfTriumph
Re: WS2811
Files here
ws led.fcfx
(9.46 KiB) Downloaded 289 times
ws led.c
(57.34 KiB) Downloaded 269 times
Re: WS2811
Can you add initialise as that is missing, then a small delay, then the colour and refresh functions before the loop.
Within the loop just add a delay.
TheShadowOfTriumph
Re: WS2811
I do it
Re: WS2811
After applying the Fix mentioned here Does your project now compile OK and works?
