jgu1
- Has thanked: 839 times
- Been thanked: 205 times
Post
by jgu1 »
Hi all!
I can´t find the ws2811 or ws2812 rgb led in the component list, not even if I use the search
For testing the esp32 s3 mini
Has it been removed from FC10 or get another name?
Please
Jorgn
- Has thanked: 442 times
- Been thanked: 661 times
Post
by chipfryer27 »
On mine it's under Components > Outputs > LEDs
- Screenshot 2025-04-24 171820.jpg (126.97 KiB) Viewed 5247 times
jgu1
Post
by jgu1 »
Hi Chipfreyer!
Thank´s for fast reply. That´s strange, in mine I only see:
Is there anywhere I can make a settings?
I have full update.
- Skærmbillede 2025-04-24 183803.png (122.88 KiB) Viewed 5244 times
Post
by chipfryer27 »
Under component libraries change "Show Components" to 2D and 3D
That should do it.
jgu1
Post
by jgu1 »
Wow, (lian, as far I remember
) I forgot that, now all component are there again.
Thank you.
Nice evening
Jorgen
jgu1
Post
by jgu1 »
You do it very fine
As I gues you know the led on the board on the ESP32 S3 Zero is a RGB led and is WS2812 I can´t get it work with FC10, also not in simulation.
I found an examble on web Arduino IDE and this work
ope you will take a look and see what I do wrong, please.
- Flowcode1.fcfx
- (10.83 KiB) Downloaded 148 times
jgu1
Post
by jgu1 »
Solved, Refresh missing
Br Jorgen
