Hi Dirk.
I 'm not sure when it will be ready, as its for other target devices as well.
It will be done as soon as possible.
PIC18F15Q41
- Has thanked: 717 times
- Been thanked: 777 times
Re: PIC18F15Q41
PWM cannot be mapped to port C, only to ports A and B. Port C is not displayed. I have ported a project to the 18F15Q41. I2C software then gives an error. If I create a new project with the 18F15Q41, the compiler runs without errors. What can this be?
Best regards
Dirk
Best regards
Dirk
Re: PIC18F15Q41
I2C is not an easy fix.
We need to allocate time for this.
We do plan on fixing it as soon as we can.
As for the PWM, I have attached a temporary fix.
For the fcdx file:
If you browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
Replace the original file with the attached version.
If Flowcode is already open, then you will need to reload your project.
If you run any component updates, then the fcdx you added will be overwritten.
For the fcpx file.
the path is
I Would suggest you close Flowcode before adding the files.
For the fcdx file:
%ProgramData%\MatrixTSL\FlowcodeV10\FCD\PIC\If Flowcode is already open, then you will need to reload your project.
For the fcpx file.
the path is
%ProgramData%\MatrixTSL\FlowcodeV10\Components\- Attachments
- cal_pwm.fcpx
- (12.96 KiB) Downloaded 264 times
- 18F15Q41.fcdx
- (51.91 KiB) Downloaded 273 times
Re: PIC18F15Q41
Hi Ben, Hi Steve,
here's a comment about the I2C component to bump up the thread and make sure it's not forgotten. I'm including Ben's post so that it's clear what this is about.
I think we've looked at this I2C before and ran into issues however on having another look I've spotted more information in the form of additional helper manuals from Microchip and so I'm happy to have another go. Just seeing if I can get my hands on some hardware to help with the testing.
- Has thanked: 615 times
- Been thanked: 807 times
Re: PIC18F15Q41
Hi Dirk,
We're certainly making progress with I2C but not quite there just yet.
What's the problem with MIDI?
Re: PIC18F15Q41
Hello Ben,
it looks very good. I2C, midi and pwm hardware now compiles without errors. However, there is a problem with the eeProm.
Could you please take another look at it? Then I will run the test with the chip and post the results here.
One more question:
What is the flash eprom component? With this component, the compiler also runs without errors.
Thank you
One more question:
Thank you
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:321:19: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:321:22: error: (182) illegal conversion between types
int -> volatile union S9
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:326:16: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:326:19: error: (182) illegal conversion between types
int -> volatile union S14
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:333:19: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:333:22: error: (182) illegal conversion between types
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:347:19: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:347:22: error: (182) illegal conversion between types
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:352:1: error: (192) undefined identifier "NVMCON2"
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:354:16: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:354:19: error: (182) illegal conversion between types
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:357:23: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:357:27: error: (207) simple type required for "=="
NOT volatile union S14
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:361:19: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_EEPROM.c:361:22: error: (182) illegal conversion between types
(908) exit status = 1
Error returned from [xc8.exe]
