ADS111x component add single-ended or two differential inputs
Has thanked: 246 times
Been thanked: 258 times
would it be possible to add an option to select four single-ended or two differential inputs ?
and also the PGA gain?
This is also an ADS111x
ADS1115: four single-ended or two differential inputs with comparator and PGA
louise56m
Re: ADS111x component add single-ended or two differential inputs
Post by louise56m »
Hi, great suggestion! Since the ADS1115 supports both modes, adding an option to select between four single-ended or two differential inputs, as well as configuring the PGA gain, would be very useful. Definitely worth considering!
maybe you can make an a second component like a ADS1115 with fixed differential inputs
0Ain and 1Ain
2Ain and 3Ain
that would already help
I looked at the component and realized that read differential already exists but it's hide.
I "unhide" read differential volt, but still not works
Read raw differential is still completely empty but already exists.
That would be great if it worked " Read raw differential"
One more problem.
ADS1115 has an alert pin. If I use a board with I2C , the pin is not avaible.
In the propertis, I can select unconnect but then I get a warning and an error.
If i selsct an unused pin it's working
