2D Panel Zoom Function
liudeqiang_2008
Has thanked: 11 times
Been thanked: 2 times
Flowcode v10 2D Panel Zoom Function
Post by liudeqiang_2008 »
When using 2D panels, the default icons and fonts are inconsistent. Some are clear, some are fine, and some are too small to be easily recognized.
And the panel cannot be zoomed in or out as a whole, only by manually enlarging the small icons one by one, then the accompanying fonts become larger. Manual dragging can also cause icon deformation, affecting the aesthetic appearance of the interface.
I tried adjusting the font size in the global settings, but it didn't seem to be helpful here.
Can we add an overall panel zoom function (similar to a flowchart window, where holding down CTRL while scrolling the mouse can zoom in and out of the entire panel).
Alternatively, select a single or multiple icons that need to be enlarged and right-click to set the zoom ratio for them.
This is what I fell during use, and it is also possible that there are related functions but I am not sure. So please let me know how to do it.
Thanks,
Br, Deqiang
屏幕截图 2025-07-31 215331.png (169.42 KiB) Viewed 5590 times
Has thanked: 311 times
Been thanked: 479 times
Re: 2D Panel Zoom Function
liudeqiang_2008 wrote: ↑
Thu Jul 31, 2025 3:09 pm
Thanks for the suggestion. The 2d panels in the next major version of Flowcode will have a zoom feature. We're getting close with this new version and we should be able to announce more details in the next month or so.
Has thanked: 795 times
Been thanked: 858 times
There is an option to make all selected components the same size as the first selected component.
First select the component that is the required size.
Resize 1.png (76.43 KiB) Viewed 5574 times
Hold the Ctrl key down and left click all the other components to want to resize.
Click the resize option on the top of the 2D panel.
Resize 2.png (126.09 KiB) Viewed 5574 times
Now all the selected component will be the same size.
Resize 3.png (135.81 KiB) Viewed 5574 times
A tip. When a component is selected, select the Position tab, then select Yes for Lock aspect ratio.
You then then drag the corner to resize and the component will remain in shape.
liudeqiang_2008
Steve-Matrix wrote: ↑
Thu Jul 31, 2025 5:44 pm
This is a good news, looking forward to the new version. :D
Br, Deqiang
liudeqiang_2008
medelec35 wrote: ↑
Thu Jul 31, 2025 5:52 pm
You then then drag the corner to resize and th component will remain in shape.
Thank you very much for the clearly explain.
It works very well following your step.
Thanks again.
Br, Deqiang
S_VE
Has thanked: 56 times
Been thanked: 4 times
Post by S_VE »
Greetings,
I have FC V8 and FC V9, thinking of upgrading to V10 Now,
Could you please suggest if I should wait for the NEW version, or go ahead and buy V10 Now?
S_Ve
S_V
S_VE wrote: ↑
Fri Aug 01, 2025 3:14 pm
We have not finalised pricing for the next version of Flowcode, so I cannot answer this yet.
