Attiny85 pwm wrong output
simisv
Has thanked: 5 times
Been thanked: 5 times
Flowcode v10 Attiny85 pwm wrong output
Post by simisv »
Hi guys
I'm trying to use pwm with Atmega85 using 8Mhz internal oscillator .
The result is way off and unstable . Instead of 38khz the output is starting from 13khz and dropping slowly to 8khz or lower .
Any suggestions ?
Thank you
simisv
Flowcode v10 Re: Attiny85 pwm wrong output
Post by simisv »
For some reason I cant attach more then 3 pictures .
simisv
Post by simisv »
And the flowcode 10 file .
attiny85_pwm_test2.fcfx
(9.23 KiB) Downloaded 171 times
