WS8211 component encountered an error and cannot be used anymore (solved)
niedian
Has thanked: 3 times
Been thanked: 5 times
Flowcode v10 WS8211 component encountered an error and cannot be used anymore (solved)
Post by niedian »
Hello, this error occurred after upgrading. What should I do,
In the first few days, after reporting to WS8211, I sent the file you posted on the forum( download/file.php?id=10494 )I copied and pasted it into% ProgramData% \ MatrixTSL \ FlowcodeV10 \ Components, and encountered the error after upgrading today. What should I do? Acknowledgments
niedian
Re: Hello, this error occurred after upgrading. What should I do
Post by niedian »
The upgrade is proceeding normally, but when adding the ws8211 component after the upgrade, the above error message appears
niedian
Post by niedian »
After deleting LEDw_S2811.fcpx and upgrading it again, the error shown in the above diagram still occurs。
Has thanked: 794 times
Been thanked: 858 times
Re: WS8211 component encountered an error and cannot be used anymore
Hi niedian
Many thanks for the spot.
I can replicate the issue, so I have attached an updated version for you to try.
%ProgramData%\MatrixTSL\FlowcodeV10\Components
Place the attached component.
LED_WS2811.fcpx
(19.34 KiB) Downloaded 276 times
niedian
Post by niedian »
I did it your way and it's back to normal. You're amazing, thank you very much.
That's great, your welcome
Thanks for letting me know.
I will make sure the updated version goes to the component database.
niedian
Post by niedian »
After today's upgrade, ws2811 still has the above-mentioned issues.
Has thanked: 478 times
Been thanked: 713 times
Post by chipfryer27 »
Please reread Martin's post of above. He will work on having the fix published. Meanwhile, until it is published, if you update then you will revert back to the non working version.
If you download Martin's "fix" as per above, then the chart will work again.
It takes time for your fix to become "live", so to speak.
