Hello, this error occurred after upgrading. What should I do,
In the first few days, after reporting to WS8211, I sent the file you posted on the forum( download/file.php?id=10494 )I copied and pasted it into% ProgramData% \ MatrixTSL \ FlowcodeV10 \ Components, and encountered the error after upgrading today. What should I do? Acknowledgments
WS8211 component encountered an error and cannot be used anymore (solved)
niedian
- Has thanked: 3 times
- Been thanked: 5 times
- ws2.jpg (14.76 KiB) Viewed 4592 times
- ws1.jpg (9.83 KiB) Viewed 4592 times
- Has thanked: 794 times
- Been thanked: 858 times
Re: WS8211 component encountered an error and cannot be used anymore
Hi niedian
Many thanks for the spot.
I can replicate the issue, so I have attached an updated version for you to try.
Place the attached component.
%ProgramData%\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new component to work
- LED_WS2811.fcpx
- (19.34 KiB) Downloaded 276 times
That's great, your welcome
Thanks for letting me know.
I will make sure the updated version goes to the component database.
- Has thanked: 478 times
- Been thanked: 713 times
Please reread Martin's post of above. He will work on having the fix published. Meanwhile, until it is published, if you update then you will revert back to the non working version.
If you download Martin's "fix" as per above, then the chart will work again.
It takes time for your fix to become "live", so to speak.
