App Developer DSP Level Tick is missing
Has thanked: 246 times
Been thanked: 258 times
DSP Level Tick is missing?
How to use the DSP Level?
I like to ReadAverage from 200 samples but I miss a Tick.
I tried the sample on the help but the compiler is missing also a tick like me....
Has thanked: 647 times
Been thanked: 856 times
Re: App Developer DSP Level Tick is missing
Hi Stefan,
I've redone the wiki example for you now so that it works with the latest component.
Level.fcfx
(16.54 KiB) Downloaded 724 times
I've also added a new property to allow the min / max values to remain rather than decaying over time.
Let me know if you have any problems.
Perfect! Its working now.
Very good idea from you!
If you can add another command (ResetPeak, ResetTrough) to set the value back to 0 that would be fantastic. I could then reset the value after ReadPeak or whenever I need it to reset. I hope it works with int and long.
Hi Stefan,
That's a good idea. I've added it for you now.
Should work fine with int and long.
Let me know how you get on.
With reset command:
Maybe I did not do the right way.
I put a switch to reset the Peak's but it shows always 0 and 159
With decay on peak:
it's working nice
Level_reset.fcfx
(19.4 KiB) Downloaded 761 times
I tested the Level reset program with the scope.
Every thing look fine but the min Value and max Value is always 0 and 159.
I think there is a problem with the DSP Level component
Level_reset_osciloscope.fcfx
(19.75 KiB) Downloaded 777 times
Hi Stefan,
Many thanks for letting me know. I've made some further optimisations and changes to the level component now and hopefully these will work to solve the problems you're having.
Now it's perfect!
Thanks a lot
