I have attached the basic test file I used.
You will need to add your backpack LCD component, so Flowcode knows the component you want to use, then delete it.
Right-click on the LCD that is currently on the 2D panel and select Replace....
The LCD will then be replaced with backpack version.
HMC5883L Bug or me!
- Has thanked: 713 times
- Been thanked: 775 times
jgu1
- Has thanked: 829 times
- Been thanked: 204 times
Re: HMC5883L Bug or me!
Hi Martin!
Perfect, now the HMC5883 work with your examble (think you have made it in FC11 Created in a newer version, work in FC10) now I can go on with my project.
I will check the QMC later with your examble, of course change the device. Futhermore, I laern to change display /component fast and easy also, very smart.
Thank you very much Martin for your job, have a nice weekend, 10 stars again to you
Jorgen
Jorgen
