FC11 ESP32-S3 BLE error
Has thanked: 246 times
Been thanked: 258 times
Re: FC11 ESP32-S3 BLE error
First the good news.
BLE is also working with the ESP32-Pico
I tested the client.
It searches for devices and finds them, but it does not display any names.
If I simply select a device number to connect, for example no. 2, and that is the server (Flowcode), then I can receive and display the sent string. :)
Has thanked: 647 times
Been thanked: 856 times
Ok thanks for letting us know I'll investigate this and see if I can replicate.
BLE also works with ESP32-C3 perfect :)
I couldn't test with ESP32-C6 because I can't compile C6.
I have a few more suggestions:
A command to set the BLE name at startup as with classic Bluetooth.
Establishing a fixed connection to a BLE using the BLE-MAC address.
Send receive Int_Array would be good to have so that BLE would be compatible with Uart component , Bluetooth classic component and the App developper comport component. Many applications use 16 bits. Probably the other array send/receives are not very important or useful.
More good news.
Interrupt and string receive work perfectly on ESP32-S3 with BLE.
I can already test part of it?
I'll have a look into the PC/Web devloper components next so we have a full set.
I'm on it, I think we have already released the web developer version of a component, I'll check on this as I'm a little fuzzy on how I left things with Steve. I made a quick demo and Steve wrapped it into a finished webdev component.
For PC developer, this afternoon I've written a DLL to interface the Windows Bluetooth API (will need at least Win10 for this to work) and I've written a component to go around this. Just need to test it all works now. Hopefully later today or tomorrow we will have something I can share.
Right this is largely working for me now but it needs more work to make it a bit more user friendly in terms of the usual read/write functions.
First you need the DLL which needs to be extracted and placed here:
C:\Program Files (x86)\Flowcode v11\API.DLL folder.
BLE_SPP_DLL.zip
(101.93 KiB) Downloaded 448 times
Next you need the BLE component. Here is the exported component file that needs to live here:
C:\ProgramData\MatrixTSL\FlowcodeV11\Components
BLE_GATT_SPP.fcpx
(3.05 KiB) Downloaded 454 times
Lastly here is the component source code, it has a little code in the main as a basic test I've been trying out.
BLE GATT SPP.fcpcd
(44.2 KiB) Downloaded 466 times
Let me know how you get on.
Has thanked: 311 times
Been thanked: 479 times
BenR wrote: ↑
Mon Dec 22, 2025 3:34 pm
I created a component, but it probably needs a little extra effort (e.g. suitable icon) to be fully complete. Hopefully @BenR can add an icon and get that released as a library component (but might need to wait until the New Year).
Hi Ben, Hi Steve
Thank you very much.
BLE also works with the App Developer now. Perfect!
Running a scan and selecting the right module with the address is also perfect.
Sending and receiving in both directions is perfect!
I will also test with the web developer.
I can already work with read and write buffers, but it would be nice if BLE ESP32 and BLE App could read/write in the same style. I mean read/write string, byte, array, int array :) that would be easier for me and others.
Here is an example from the ESP32 SPP.
for comparison:
Hi Stefan,
Right should all be available for you now via the library updates.
You will need a new version of the DLL for the PC Developer BLE component which now tells you how many bytes are in the receive queue rather then just a true/false.
BLE_SPP_DLL.zip
(113.2 KiB) Downloaded 469 times
