ESP32 UART-USB Brige How to use
Has thanked: 245 times
Been thanked: 256 times
Re: ESP32 UART-USB Brige How to use
Hi Martin
Thanks for the support. I tried, but I always end up with a new error and then I get a little lost. I'll keep trying.
ERROR: Directory "C:\C#_sourcecode\_#FC11\Tiny_usb\main" does not exist! Please specify a valid component under C:\C#_sourcecode\_#FC11\Tiny_usb or try to use --path
C:\C#_sourcecode\_#FC11\Tiny_usb>ERROR: Directory "C:\C#_sourcecode\_#FC11\Tiny_usb\main" does not exist! Please specify a valid component under C:\C#_sourcecode\_#FC11\Tiny_usb or try to use --path
Has thanked: 173 times
Been thanked: 989 times
Post by mnfisher »
Something looks awry with the path ?
How (and where) are you creating the flowchart?
I made a copy of supplementary.c supplementary.h from the supplementary folder to Tiny_usb
I did not help...
Has thanked: 300 times
Been thanked: 465 times
May also need "main"?
Post by mnfisher »
Yes - supplementary.h & .c need to go into tiny_usb (project directory) /main/includes - and add includes to CMakeLists.txt as above.
ok I create main and all...
In file included from C:/Users/Kfs-Forschung/Desktop/esp-idf-2/mtxesp32_s3_sdkconfig/main/esp-project.c:20:
C:\C#_sourcecode\_#FC11\Tiny_usb\tinyusb_test.h:64:10: fatal error: supplementary.h: No such file or directory
Post by mnfisher »
Odd - the main directory should be created with the project - you could try either pasting the .h and .c files into the supplementary code (instead of the #includes) or give them a fixed address (#include "c:/test/file.h")
Hi Martin
I haven't had any success yet.
But I've noticed that when I connect UART0 to pins GPIO43 and GPIO44,
I can no longer flash the ESP32-S3 as easily.
I have to press the boot button and plug in the USB-C, then flash and remove the USB-C again and plug it back in.
But when I deactivate UART0 again, I can flash comfortably with Flowcode.
So something is happening with the built-in UART to USB bridge. :)
Post by mnfisher »
Some progress? Compiling okay now? Does it appear to connect to USB with a new port?
Can you post your code so far?
Hi Martin
I used another computer. I tested the two UARTs with it and everything is fine.
Later this week, I will perform the same tests on the other computer where I had the problems.
I tried to use the bridge there.
My testfirmware:
Software.zip
(297.73 KiB) Downloaded 452 times
The image shows how UART0 and UART1 work and, incidentally, how UART1 is only slightly delayed and not, as assumed, only when uart0 is finished.
