Flowcode v11. ATMEGA328 3xchannel PWM not compiling
Mcat
Post by Mcat »
Hello!
My project on ATMEGA328 uses three PWM channels. Everything works fine in the simulator, but it won't compile and gives errors like the ones in the picture. Please help.
Has thanked: 292 times
Been thanked: 458 times
Re: Flowcode v11. ATMEGA328 3xchannel PWM not compiling
I've just tried compiling an ATMEGA328 with PWM and it compiles without error for me. Make sure you are up-to-date with library updates.
Also, it was tricky to see what the error is from a screenshot. In future, it is much easier to solve problems if the output is available in text (e.g. by attaching the generated msg.txt file to a forum post).
It's also very useful to attach the fcfx file too as this saves a lot of time trying to replicate a project that exhibits your problem.
If library updates does not solve your problem, please post these files here and we will investigate further.
Has thanked: 616 times
Been thanked: 814 times
It looks like the specific error being generated it due to the 7 segment quad component pin connections, something there is referring to PortA which doesn't exist on the device you're using.
Maybe try going through the properties and checking there isn't a hidden pin thats referring to PortA.
Mcat
Post by Mcat »
Hello!
Thank you for your reply. I updated the component library, but the problem remains.
Everything simulates fine, but it still won't compile.
Project files:
PWM Nano328.msg.txt
(3.87 KiB) Downloaded 151 times
PWM Nano328.fcfx
(32.61 KiB) Downloaded 155 times
Has thanked: 724 times
Been thanked: 783 times
From Ben's post, Please pay attention to this:
BenR wrote:
Thu Dec 18, 2025 10:16 am
Select the 7seg Quad component on the 2D Legacy panel then right click and select properties.
Within the properties change any pin that has Port A selected.
E.g. the top pin is connected to port A.0 which does not exist.
Port A does not exist.png (139.06 KiB) Viewed 2107 times
As Ben stated port A does not exist, hence not able to compile.
Mcat
Post by Mcat »
Hello!
Everything worked out, thank you.
The maximum PWM frequency is 31 kHz. Does the standard PWM component not provide FAST_PWM mode? Is it possible to increase the PWM frequency?
