Hi Martin
Just had a look and now see your reply. I'm sure you are aware, it appears to affect the data recorder as well as scope.
PWM Woes
- Has thanked: 425 times
- Been thanked: 646 times
- Has thanked: 694 times
- Been thanked: 766 times
Re: PWM Woes
Thanks Iain.
Yes, as I believe it's the same API that controls both.
However it looks like it will take up too much processing power.
Therefore we will be leaving it at as it is.
Sorry for any inconvenience.
Re: PWM Woes
Side note - The hardware actually performs the PWM. Side note 2 - Selection of the INTO pin seems not to apply just to the pin. Seems that all pins (IOC) are involved. Regardless of which pins are activated, the interrupt macro runs.
Re: PWM Woes
Depending on chip (I don't have datasheet to hand), IOC can operate on individually selected pins, a group of pins or a port. If a group or port then any pin change within that group calls the IOC routine. Therefore in your routine you first need to establish which pin in the group caused the interrupt then act upon that.
Many older PICs had IOC only on a few pins on Port B. Any one of those pins having a change of value would trigger the interupt. In the interupt routine you had to test to see which pin had changed and act accordingly.
Re: PWM Woes
I see -Thanks Chip!
The selections in the interrupt component differentiate between IOC and Int0 so I think that selecting int0 should give me the individual action. However, selecting int0 allows all portA pins to run the interrupt macro. I suspect that FC sees no difference. Maybe it's flipped and IOC is really int0? I will check that out.
- Has thanked: 573 times
- Been thanked: 757 times
Re: PWM Woes
Hello Alan,
Is it this you mean?
Looking here and the definition file looks correct in that the INT0 should be single pin and the IOC should be multipin, The registers being set look to be correct too. If you have example code demonstrating the problem then looking at the .fcfx project file and associated generated .c file might be useful.The selections in the interrupt component differentiate between IOC and Int0 so I think that selecting int0 should give me the individual action. However, selecting int0 allows all portA pins to run the interrupt macro. I suspect that FC sees no difference. Maybe it's flipped and IOC is really int0? I will check that out.
