Compile problem with FC11
B2CAP-V6
Been thanked: 7 times
Re: Compile problem with FC11
Post by B2CAP-V6 »
Yes, everything is up to date, and I still have the problem.
As explained above, I uninstalled and reinstalled FC11 and all the databases covered by the licenses I purchased.
B2CAP-V6
Post by B2CAP-V6 »
I just uninstalled MPLAB and tried with another program, but it's the same.
I don't know what to do anymore. It works on your end but not mine; everything is up to date, and it still doesn't work.
I'm going home today and I'll download FC11 on another computer and let you know the result (I think it should work since it works for you).
After that, if you're willing, the only remaining option is to take control of my computer via TeamViewer, for example.
Has thanked: 308 times
Been thanked: 472 times
Can you please upload the "fcxlog.txt" file for this project as this may help us see why this project is failing to compile for you.
Also, here is a screenshot of the library files that are being used on my PC when I successfully compile your project:
Screenshot 2026-02-27 090939.png (42.65 KiB) Viewed 4335 times
Does your window (Help...Library Updates) show the same files and current versions?
B2CAP-V6
Post by B2CAP-V6 »
I replied this morning, but my replies are no longer showing up!
I said I was going home today (which I am now) and I was going to download FC11 on another computer. I think it will work since it works for you.
I still don't understand why it's not working.
If you don't mind, could you take control of my computer via TeamViewer, for example, if the problem persists?
B2CAP-V6
Post by B2CAP-V6 »
oups
Now the file
Thermo_Baro.fcxlog.txt
(113.95 KiB) Downloaded 518 times
B2CAP-V6
Post by B2CAP-V6 »
No I don't have the same files
look at the attachment
Capture d’écran 2026-02-27 173812.jpg (18.45 KiB) Viewed 4305 times
Has thanked: 474 times
Been thanked: 705 times
Post by chipfryer27 »
If you tick the box at the bottom "afficher les fichiers a jour" it should give a list of up to date files and you can compare there.
You would need to tick "Afficher les fichers a jour" to see the files that are up-to-date on your system. (edit: ninja'd by chipfryer27!)
But I think I have found the issue in the fcxlog file. It is showing that the PIC_CAL_IO.c and PIC_CAL_IO.h files may have been modified. I have attached the latest ones from Flowcode v11 and maybe you should replace your files with these (they will be in the "%PROGRAMDATA%\MatrixTSL\FlowcodeV11\CAL\PIC" folder).
If you replace these files, restart Flowcode and try again please.
PIC_CAL_IO.h
(13.53 KiB) Downloaded 468 times
PIC_CAL_IO.c
(5.64 KiB) Downloaded 543 times
B2CAP-V6
Post by B2CAP-V6 »
Thanks Steve,
Now it is ok I compile correctly.
Really a thousand thanks again
Capture d’écran 2026-02-27 181915.jpg (49.84 KiB) Viewed 4278 times
B2CAP-V6
Post by B2CAP-V6 »
Thanks also to everyone who responded to help me
