Hi All,
I wonder if you can help, please. I have been working on a project I need a 12bit ADC for. I have chosen the PIC 16F1788 for the job and built the hardware. I have just gone to start programming it and discovered that Flowcode's ADC properties for that IC are showing the ADC resolution is fixed at 10 bit. I have been back to the datasheet and it is quite certain that it has 12Bit ADC's. I have checked the PIC16F1789 and that shows the same.
Is this that Flowcode can't work to 12bit ADC resolution or is it an error in the configuration files for these IC's please?
Many Thanks.
Simon
PIC16F1788/9 ADC Resolution
simon-sandtcontrols
- Has thanked: 9 times
- Been thanked: 11 times
- Has thanked: 311 times
- Been thanked: 479 times
Re: PIC16F1788/9 ADC Resolution
Thanks for reporting this. I wonder if it is related to this post:
viewtopic.php?t=1505
Anyway, we'll have a look and get this fixed.
simon-sandtcontrols
Thanks Steve,
I think it's slightly different symptoms. I can't change the resolution from 10bit in the ADC properties, it's greyed out. I haven't tried simulating it or compiling it.
Simon.
Simon.
- Has thanked: 647 times
- Been thanked: 856 times
Hi Simon,
Hopefully resolved for you now via the library updates.
Let us know how you're getting on.
simon-sandtcontrols
Hi Steve,
I have just done the update, it's now fixed at 12bit resolution, it's fine for what I want, but is that correct it can't be changed between 10 & 12?
I haven't finished the program for it yet. I will update when I load it into the IC.
Thanks.
Simon.
Thanks.
Simon.
- Has thanked: 795 times
- Been thanked: 858 times
No you can't change within properties from 12 to 10bits and vice versa.
What you can do is read as 12 bit and convert to 10bit using calculation or using the Map component Component Libraries > Math
If reading is a bit unstable, you can even use software filters that are also available within Math e.g. rolling filter
Other things to try is set the conversion speed of the ADC to be as slow as possible and increase the Acquisitions Cycle higher than the default value.
I will see if I can find details on that.
One link to try is this
simon-sandtcontrols
OK, that makes sense. I wasn't sure as it appeared to be an option in the properties. For what I want fixed at 12 bit is fine. I haven't tried the filters or math function, I usually convert to a lower resolution using a calculation. I will have a play around. Hopefully the input I have will be fairly stable, but that's not always the case.
Thanks for your help with this. I will confirm it works when I load it into a PIC later.
Simon.
Simon.
simon-sandtcontrols
Hi All,
Sorry for the delayed reply, a bit of unexpected self oscillation in my circuitry due to a power supply line moving by 10mV to sort out. I can now confirm that it is running successfully as a 12Bit ADC in hardware.
Thanks for the help.
Simon
Simon
