adc_filter
d820513
Has thanked: 2 times
Been thanked: 1 time
adc_filter
Post by d820513 »
Hello guys, I can't figure out the filter, can someone explain to me how it should be right for everything to work:?
d820513
Re: adc_filter
Post by d820513 »
how to apply this filter on ADC should it work??? who knows show an example on atmega 328p
Has thanked: 246 times
Been thanked: 258 times
Re: adc_filter
Hi d820513
You need to connect and use a filter command.
My example is not an Atmega but it shows you how it should work.
It is possible to use the AD directly as a DSP input, but I always use the DSP input
example:
FC9_Post_DSP_Filter.fcfx
(11.48 KiB) Downloaded 413 times
AD directly as a DSP input:
But I always use the DSP input:
d820513
Re: adc_filter
Post by d820513 »
Thanks, everything works great
