adc_filter
d820513
- Has thanked: 2 times
- Been thanked: 1 time
adc_filter
Hello guys, I can't figure out the filter, can someone explain to me how it should be right for everything to work:?
- adc_filter.png (201.36 KiB) Viewed 2602 times
- Has thanked: 246 times
- Been thanked: 258 times
Re: adc_filter
Hi d820513
You need to connect and use a filter command.
My example is not an Atmega but it shows you how it should work.
It is possible to use the AD directly as a DSP input, but I always use the DSP input
example: AD directly as a DSP input: But I always use the DSP input:
