I'm trying to initialize an SD card on a ESP32S3, but I keep getting a 255 return (no card) instead of 0 (card ok).
Is there something else I need to configure to make this work with the S3? With the ESP32 wroom32 This worked very well.
ESP32S3 SD-card init problem
- Has thanked: 246 times
- Been thanked: 258 times
- Has thanked: 647 times
- Been thanked: 856 times
Re: ESP32S3 SD-card init problem
Hi Stefan,
What type of card are you using? Not every card supports the 4-bit mode, maybe try the 1-bit mode and see if that works.
We are using the 4-bit mode on an ESP32S3 in house and it is working very well but we have to be careful about which cards we use.
All SDHC or SDXC cards are suppost to support 4-bit mode but this is not my experience.
Glad to hear it's working for you.
I always use the same type of SD card—a 32GB SanDisk—for the 4-bit version.
It worked fine with the PIC32 and ESP32 WROOM.
I tried a different board—this time from SparkFun—and the card initialization caused problems there as well.
I checked the pins and they should be okay.
I think it's just a startup issue in my program?
- 2026-04-23_17-28-22.PNG (77.5 KiB) Viewed 7588 times
The esp may have a different return value for the init. I may simply be ignoring it. Might be worth seeing if the other functions work ok and ill have a gander at the code to check the return values.
I tried to ignore the return value and create a file, but it didn't work.
It looks like the ESP32S3 has a lot of advantages.
For example, data sampling works directly in the interrupt macro,
and resetting the watchdog timer no longer requires a wait time of a few milliseconds.
Unfortunately, the SD card isn't working yet.
Hello Stefan,
As I say we have it working great on the ESP32S3 so not sure wehat the problem is here.
This is my firmware project file and the part that initialises the card. We are sure the card is running as we put bitmaps and font data onto the card and that's all working great.
I've checked everything on the board,
and it's all fine.
Do I still need to include any files?
I also have a wonderful test board with touchdisplay here.
Maybe there's already a test program?
ESP32-S3 Advanced 16-bit Board
Sd-card on board
and it's all fine.
Sd-card on board
I created a small test program.
It works in the simulation, but in hardware it never exits the loop.
