Warning message
S_VE
Has thanked: 56 times
Been thanked: 4 times
Flowcode v11 Warning message
Post by S_VE »
Greetings
I am using Flowcode V11 Prof license.
uC is PIC18F47Q10
I am getting a warning message while compiling ( please see the picture attached )
is this a bug, OR can it be ignored. Please help.
one observation,
Compiler gives this warning only when i add Modbus / Uart component to the 2D panel
even if i do not add "INITIALIZE" Macro to the Main flowchart code.
with out adding MODBUS / UART component, the compiler compiles without this WARNING.
Flowcode V11 PIC18F47Q10 Warning msg 02.jpg (75.25 KiB) Viewed 1486 times
Flowcode V11 PIC18F47Q10 Warning msg 01.jpg (129.09 KiB) Viewed 1486 times
S_V
Has thanked: 647 times
Been thanked: 856 times
Re: Warning message
Thanks for letting us know I beleive the warning is nothing to worry about but I have also managed to fix and remove it now via a library updates related fix. Use the Help -> Library updates menu item to get the latest updates.
S_VE
Re: Warning message
Post by S_VE »
Thank you Ben,
Now it compiles without Warning
Thanks once again,
S_V
