SN74HC595 Multiplexed 7 seg LED display
Has thanked: 177 times
Been thanked: 1027 times
Post by mnfisher »
A simple display (4 digit) using a shift register.
A couple of points:
1) Pull the OE (output enable) pin to ground either in code or in hardware.
2) Multiplex needs to be called regularly - ideally use an interrupt - as per demo. However it could be called in a loop (with a delay). Something like 240Hz is ideal. Setting up a timer interrupt for each MCU is slightly tricky - so left to the user here.
3) Multiplex bit-bangs the data to the shift register. I tested on an Arduino (16MHz) - there is a a chance that some MCUs might be too fast - add some 1uS delays (in the code but disabled here) I've not tested this - it might cause issues on some MCUs (esp32) depending on how the delay is implemented in FC.
4) The display needs to be connected to the shift register segment A to Qa - B to Qb etc with dp to Qh. Assuming standard segment layout. For common cathode the component inverts the data - not tested (I don't have any displays like this) - polarity can be set in properties.
The Display macro takes a decimal point position - and attempts to 'pad' with 0s rather than have leading spaces (so 0.001 not "0. 1" or " . 1")
Negative numbers are not handled (nor the possible 7 seg character set (A, B, C, E, H, L etc)))
It simulates (sort of) - the 2d panel component just displays the value...
SN74Display.fcpx
(2.94 KiB) Downloaded 320 times
SN74_Test.fcfx
(10 KiB) Downloaded 315 times
ShiftReg.fcfx
(22.23 KiB) Downloaded 317 times
andeug
Has thanked: 40 times
Been thanked: 6 times
Re: SN74HC595 Multiplexed 7 seg LED display
Post by andeug »
Martin, thank you very much for the time invested in creating this component - I know it came due to the challenges I have experienced with the multiplexed display from my digital clock project. At the moment, I am experiencing some troubleshooting with my project and a lack of time, so please accept my apologies if I don't respond as often to the topic(s).
One question - how do you deal with SN74HC595 (your component) vs. TPIC6595 (the component from my clock project)?
The two chips do not use an inverted LUT, but they do differ in how their outputs behave electrically, and that’s what often creates the impression of “inverted logic”. The SN74HC595 is a logic-level shift register with push‑pull outputs, while the TPIC6595 is a power shift register with low‑side DMOS switches. Because the TPIC6595 sinks current instead of sourcing it, the effective logic at the load can appear inverted even though the internal storage bits are not.
🔧 Core functional difference
SN74HC595
• 8‑bit shift register + latch
• Push‑pull CMOS outputs
• Output pin goes HIGH = +V, LOW = 0V
• Drives LEDs or logic directly in the “normal” way
• No inversion in the output stage
TPIC6595
• Low‑side DMOS drivers (open‑drain style)
• Output pin goes LOW = conducts to ground, HIGH = off
• Designed to sink current from loads connected to +V
• Loads turn ON when output = LOW, OFF when output = HIGH
🎛 Why it feels like the logic is inverted
The internal bit stored in both chips is interpreted the same way (1 = “on”, 0 = “off”), but:
• On the SN74HC595, “1” drives the output pin high, turning on a load connected to ground.
• On the TPIC6595, “1” turns the DMOS transistor off, so the output pin floats high and the load turns off.
• A “0” on the TPIC6595 turns the transistor on, pulling the output low and turning the load on.
So the load behavior is inverted, even though the logic inside the shift register is not.
🧩 Practical implications
• If you migrate code from SN74HC595 → TPIC6595, your LEDs or loads will turn on/off in the opposite way unless you invert the bits in software.
• The TPIC6595 is ideal for high‑current sinking (relays, LEDs, motors), while the SN74HC595 is for logic‑level or low‑current loads.
• Electrically, the TPIC6595 behaves like eight N‑MOSFET low‑side switches controlled by a shift register.
Post by mnfisher »
Hi Andreas,
You'd mentioned both shift registers and I had some of the SN74 chips....
The modifications should be fairly trivial - Multiplex handles all the output details - so there a few options:
1) Alter the lookup table
2) Invert the data - I attempted to do this if enable pin active was high rather than low - but .data = ~.data inverts a value.
3) Invert the value using an electronic component (a transisitor?) - I'm very much an electronics newbie....
However, do you need to invert at all if on is gnd and off is 1?
andeug
Post by andeug »
Here is the schematic that depicts the FC component I need:
Here is the prototype that I've built with TPIC6B595:
I have ordered two hats for the Arduino Uno and Mega from Mouser with Wago connectors, so I can work with the wires more easily:
https://www.mouser.se/ProductDetail/426-DFR0920
https://www.mouser.se/ProductDetail/426-DFR0921
I should be able to test this prototype within 1-2 weeks if I have time, and I will provide more feedback on the component you built for me.
Andreas
andeug
Post by andeug »
Would it be possible for you to make some cosmetic changes to the component and, for simulation purposes, add pins for L1L2 and L3? I am using all of them in my project, including DP, which is common to all four CA1-CA4. I know I can use LEDs, but I want a nicer display that includes everything.
Right now, the display component looks as follows:
What I would suggest is to overlay the display from the datasheet of the TDC.1050 and make a whole display that depicts the exact angles, L1L2, L3 and DP placements.
Eventually, if it's someone from Matrix TSL who's interested in this component, I can send it from Sweden to the UK for additional testing, and with my request to add it to Flowcode as a component, specifically for pairing with TPIC6B595.
Andreas
tdcx10x0m.pdf
(240.22 KiB) Downloaded 120 times
andeug
TPIC6B595 prototype
Post by andeug »
I have managed to wire the display board, and it all works fine:
Unfortunately, I cannot figure out how to display digits on the enclosed TPIC6B595 component, which I placed on C:\ProgramData\MatrixTSL\FlowcodeV11\Components:
TPIC6B595.fcpx
(2.94 KiB) Downloaded 86 times
Let's start with the string 1234... How do I do it?
Andreas
andeug
Re: TPIC6B595 prototype
Post by andeug »
I found it! Your component works great! :D
The flow code below allows me to display 12.34:
Now, if I want to display characters like "h", "n", "o", is there any way I can do it by telling each digit that I need a hexadecimal value? I need a separate ShowDigit macro that can display the characters of the alphabet and control each DP.
Basically, I need to define a list of numbers and constants for the entire alphabet, and then pick the letters that can be drawn on a 7-segment display as hexadecimal values.
Post by mnfisher »
Glad you have things running....
See viewtopic.php?p=21898#p21898 - where I do the characters for a MAX7219 :-)
It would take a little work to change the component - it needs to use the larger lookup table of character data and would need a 'DisplayStr' macro or similar? Multiplex might/would need to be altered to access the extra characters depending on how you want to create the displayed values?
Another option would be just to modify multiplex and pass an array of 'segment values' (each a byte) and pass this to it instead?
I don't have much time until the weekend though - and am not sure that I can find the test board I built for this :-( (It was a bit of a breadboard nightmare!)
andeug
Flowcode v11 Re: SN74HC595 Multiplexed 7 seg LED display
Post by andeug »
I am now working on a digital clock with an Arduino Uno, a DS3231 RTC, a TPIC6B595 (for high-current support), and a display called TDCR1050M (common anode), just to avoid a lot of wires and... because I like the display, the idea of using shift registers, and I like a scalable design. Unfortunately, as you can see from the schematic, I ended up with at least 24x resistors and 6x MOSFETs... and somehow an unusual HW design. I think it's easier to source an 8x digit 7-segment display already connected to a MAX7219 than to do a breadboard as I did - it took me one day to assemble it. I also have the option to use the Arduino Uno's PWM to control, let's say, the L1L2 blinking column for seconds.
To answer your questions:
Try not to make a fixed lookup table, because I will define each character in a hex value from 1 to 256, and they will become Constants in my code.
This is useful for someone who respects the wiring and knows what kind of letters will be there. But, for example, I have the Mikroe 7seg Click, where some wires are reversed and do not follow a standard. Therefore, I've had to test each address manually and see what I will get on the display, and here is the result:
I only need a field to enter the values between 1 and 256, as in the upper value, and get something. I need to be able to tell the value and the column (ideally, it would be if you could make a display configurable between 1-8 segments).
Maybe this is similar to what I did earlier in my Excel table? (I have experience with electronics, but not with coding, so I don't know if we are talking about the same) :roll:
Andreas
7-seg Click schematic.pdf
(113.59 KiB) Downloaded 82 times
Post by mnfisher »
Sounds interesting. The DS3231 is well known and easy to use - accurate too.
I don't quite follow your table - if, for example, I want to display '1' - I need to find the segment pattern for this. There are several ways to do this - but a a lookup table (an array or a LUT) is quick and linear time.
so .segs = lookup[1] ? Or if using ASCII .segs = lookup['1' - '0'] (lookup contains data for digits 0..9)
Multiplex needs to know what segments to display (so each digit is made up of 1 byte (8 bits) - where each bit corresponds to one segment) - this might be better served with 'display_data[4]' holding the segment data for each of the characters in the display and Multiplex using this?- and the DisplayTime(str) - macro can lookup / calculate the required segments.
As an alternative - if the lookup is in RAM then a SetCharacterSet(data) macro could be used?
Possibly - I think we are really trying to get the same result.
It's one of my bugbears - but I would advise avoiding using switch statements for the segment calculation...
I have seen (genuinely) large switch statements:
switch(.n) :
1: .x = 48
2: .x = 49
128: .x = 175
Which could be replaced by .x = .n + 47 (saving ~4k of flash memory)
Or
switch(.n):
1: .x = 12
2: .x = 25
128: .x = 22
Replace with .x = lut[.n] (array or LUT) - it's quicker, smaller and easier to read (FC allows a maximum of 10 values for a switch statement - so these were over multiple switch statements!
Not to say that 'switch' doesn't have uses - just that this is not it's forte!
Multiple ifs - don't do it :-)
