Cannot delete this variable because it is used in macro Main by icon Loop
andeug
Has thanked: 40 times
Been thanked: 6 times
Flowcode v11 Cannot delete this variable because it is used in macro Main by icon Loop
Post by andeug »
I have a little project I am working on, and I realized I cannot delete the variable marked in the picture below if I am choosing "Loop Forever":
Screenshot 2026-07-13 134859.jpg (65.83 KiB) Viewed 1719 times
I can rename it, but in my FC project, I cannot see it anywhere on a first view.
So I started to dig and found it on Properties: Loop, hidden on "Loop until", which was not selected.
Screenshot 2026-07-13 135405.jpg (77.82 KiB) Viewed 1719 times
Is this a bug that should be reported to Matrix TSL, or is this how FC is expected to work? Below is the project example.
buggy project.fcfx
(20.41 KiB) Downloaded 92 times
Andreas
Has thanked: 300 times
Been thanked: 465 times
Re: Cannot delete this variable because it is used in macro Main by icon Loop
Thanks for the report. As a convenience, Flowcode remembers any expression used in a Loop command. But this is hidden when "Loop Forever" is selected.
This should be fairly easy to fix - I will allow the variable to be deleted if it only shows in hidden/remembered expressions.
Has thanked: 755 times
Been thanked: 817 times
While waiting for a fix, the variable can be removed using your favorite text editor.
Before making any changes, always make a backup of the original first, as it's easy to make a mistake that will prevent your project from loading.
buggy project. modifed.fcfx
(20.2 KiB) Downloaded 29 times
andeug
Post by andeug »
I have actually fixed the issue within the same project, after digging a bit into Loop.
I have only seen this problem once, so it does not affect me (but might affect other newbies like me). :)
No problem.
For anyone else, if you do face the same issue and don't want to edit the fcfx file within an editor.
Just Right-click on the variable and select List occurrences.
Double click (or right-click and select Show) in the loop icon that appears within Icon Lists window.
You might need to change the loop type to Count, as that is only time you will find a variable.
You find the variable causing the issue (until and update hase fixed it of course).
