MCP356x1 Set to Full Shutdown mode
Has thanked: 246 times
Been thanked: 258 times
The MCP356x1 is a nice 24Bit Ad converter.
There is a one-channel, two-channel, and four-channel version
with SPI and many possibilities and features.
The AD converter is working perfect with FC11
But especially with battery-powered devices, which are usually most time turned off, the Full Shutdown mode
would help reduce power consumption during deep sleep
Would it be possible to create two command?
Set Full Shutdown Mode
Exit Full Shutdown Mode
an ESP32 is simple to set in deep sleep mode:
Has thanked: 647 times
Been thanked: 856 times
Re: MCP356x1 Set to Full Shutdown mode
I've made a new function (SetShutdownMode) for you now and rolled it out to the library update system.
Perfect! It's working nice.
Normal working, the current from the Board is 61.8mA
The deepsleep current goes down to1.6mA and to 0.3mA (300uA) with shutdown the ADC.
Soon I include a LDO to turn off Analog part and and then I expect less than 200 μA
One more little thing.
Before I set the ADC to shutdown mode, I have to stop sampling; otherwise, the program crashes and restarts instead of going into deep sleep.
Excellent glad that's working well.
I expect there is a wait for sample to be complete that is never returning once the ADC is in deep sleep mode. I'll have a look and see if we need to implement some kind of timeout to avoid hanging the entire application.
Edit: yes the SampleADC macro will block until the sample is complete. I'll add in a timeout mechanism.
Edit2: Timeout now implemented and added to the library updates. Hopefully with no negative consequences.
Nothing has changed; I need to stop the IRQ, otherwise the system will crash and restart.
Hmm could be my retry timeout count is too high. I'll think if there's a better way to do this.
With a very small battery, deepsleep has been working for several days now. Later, I'll test it with a larger battery.
For me, it works well to stop the IRQ and wait until I enter deep sleep mode.
Maybe my sampling issue is related to your timing.
I'm testing at 100 Hz, which means every 10 milliseconds.
Scope1
But I take many samples and calculate the average. 1.6mSec long
Scope2
