Problem programming Arduino mega 2560
NiamhDaniels
Has thanked: 3 times
Flowcode v11 Problem programming Arduino mega 2560
Post by NiamhDaniels »
Hiya, so sorry- i'm not sure if this is a bug or not, but I've been getting this error message when trying to compile to target. I have tried compiling to C, and copying and using the arduino IDE successfully, but it would be nice to be able to program via flow code ideally :?
Target folder: C:\Code
Source name: C:\Code\LED1.fcfx
Title: New Embedded Project
Description: New <Arduino Mega 2560> Embedded Project
Device: ARD.ATMEGA.ATMEGA2560
Generated by: Flowcode v11.0.2.17
Date: Friday, September 04, 2026 16:29:26
Users: 1
Registered to: NiamhDaniels (95939856)
Licence key: 2JM044
https://www.flowcode.co.uk
Using FCD settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV11\FCD\AVR\batchfiles\avra.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\" atmega2560 "C:\Code\LED1.elf" "C:\Code\LED1.c" "C:\Code\LED1.lst"
C:\Code>REM CRC: EA277D0C7EF9B4E537B79187D0BE7A25FA6080B4B01BE48BAF713429E4B690411241251B4A05C2B5828F4452C9F7348705C640EF477B79E0C7881D2E5EEC9BD69A0D46BD3B6AACB92DE4D84759EBB5079CA9DA2D2BBCDAE2A4D1C56CD1580BF5A24465F11D9C3B2DBA3F4E37F13004EE3637760F1F0B7DA0CC623CD30E3C7D6BAB4C3FE6151D92B8EC0ADD55E96639DAC02472BDE3806EF43AE3A028BD32A5DAE68BB191DA97CB6883A66D3C41849952BB2DD264AF32733E2C3050DA273BE4EE1FA30153290F2FAFBD2259D77AD477809E9C4D76400384BA5D2E1919BC6D834D57C406BC4A49D3F1
C:\Code>REM REVISION: 1.0
C:\Code>REM GUID: EA0828B2-5C70-41A5-8C54-F359DD5CC88B
C:\Code>REM DATE: 08\08\2022
C:\Code>REM DIR: FCD\AVR\batchfiles\avra.bat
C:\Code>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avr-gcc.exe" -mmcu=atmega2560 -Os -ffunction-sections -fdata-sections -funsigned-char -o "C:\Code\LED1.elf" "C:\Code\LED1.c" -lm -Wl,-gc-sections
C:\Code>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avr-objdump.exe" -S "C:\Code\LED1.elf" 1>"C:\Code\LED1.lst"
C:\Code>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avr-size.exe" -B -d "C:\Code\LED1.elf"
text data bss dec hex filename
426 0 0 426 1aa C:\Code\LED1.elf
Compilation successful!
Using FCD settings for linker
C:\ProgramData\MatrixTSL\FlowcodeV11\FCD\AVR\batchfiles\avrb.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\" "C:\Code\LED1.elf" "C:\Code\LED1.hex" "C:\Code\LED1.cof"
C:\Code>REM CRC: EA277D0C7EF9B4E537B79187D0BE7A25FA6080B4B01BE48BAF713429E4B69041F19754DEA3580B6825E5D6A5C09874F305C640EF477B79E0C7881D2E5EEC9BD69A0D46BD3B6AACB92DE4D84759EBB5079CA9DA2D2BBCDAE2A4D1C56CD1580BF5202CD64388F0AF24F175A82BBF7DF194C31451F662291FA2302B8E00B0793B98DE54674FED6890F09D29E6D6AF5F4CDA2A0B069D1A731E4BF7CAEBD6A00B6313A3554E78FBF27EB2E2AB377A2B2C9B1D3B75C13EB27ADD422C3050DA273BE4EEA03AAF1B2D5E9A8C92AFCC9691A050BCD9E1A3B49732FB7C850400E5B608E745107C571680B732A8
C:\Code>REM GUID: C4F77EBB-EDB0-4261-B01E-F0B1AB94E03A
C:\Code>REM DIR: FCD\AVR\batchfiles\avrb.bat
C:\Code>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avr-objcopy" -O ihex -R .eeprom "C:\Code\LED1.elf" "C:\Code\LED1.hex"
HEX file creation successful!
Using FCD settings for programmer
Launching the programmer...
C:\ProgramData\MatrixTSL\FlowcodeV11\FCD\AVR\batchfiles\avrc_arduinoB.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\" m2560 stk500v2 COM8 115200 "LED1.hex"
C:\Code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
C:\Code>REM GUID: 67C6936B-1A8D-4957-91C9-AE352304F2B6
C:\Code>REM DIR: FCD\AVR\batchfiles\avrc_arduinoB.bat
C:\Code>"C:\ProgramData\MatrixTSL\FlowcodeV11\FCD\AVR\batchfiles\..\bin\oldavrdude\avrdude.exe" -p "C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\" -P stk500v2 -b COM8 -c m2560 -U flash:w:115200
The system cannot find the path specified.
Error returned from [avrdude]
C:\ProgramData\MatrixTSL\FlowcodeV11\FCD\AVR\batchfiles\avrc_arduinoB.bat reported error code 0x3
Autoclose turned off
FINISHED
Many thanks in advance, and sorry to bother you!
Niamh
LED1.fcfx
(14.01 KiB) Downloaded 23 times
Has thanked: 177 times
Been thanked: 1016 times
Re: Problem programming Arduino mega 2560
Post by mnfisher »
Something is wrong with the command line to upload the program to hardware...
Should be '-p COMn -b 115200' wheres the speed seems to have been tacked on as the fiilename....
Can you look at what is in Build->Compiler options->Programmer as the command line and options.
NiamhDaniels
Flowcode v11 Re: Problem programming Arduino mega 2560
Very sorry for the delayed response... I've attached a screenshot of the compiler options. I tried the Mega 2560 r3 instead, and this seemed to work (I don't think the board i'm using is genuine- on the front it says mega 2560, when i think it might actually be an r3). Thank you very for your help/looking into it for me :)
Cheers,
Niamh
Screenshot 2026-09-05 133410.png (59.78 KiB) Viewed 771 times
Has thanked: 469 times
Been thanked: 698 times
Post by chipfryer27 »
When using a Mega 2560 these are my compiler settings and locations,
Compiler options.png (41.53 KiB) Viewed 766 times
Yours should be similar. However I haven't used a Mega in ages so.......
Has thanked: 300 times
Been thanked: 467 times
NiamhDaniels wrote:
Sat Sep 05, 2026 1:38 pm
The programmer options for the Mega 2560 are actually in the FCD (the chip definition file used by Flowcode) and not settable using the compiler options. As the "r3" is working, then I would just use that as the FCDs for the "Mega 2560 R3" is nearly identical to the "Mega 2560" with the exception of the programmer options.
NiamhDaniels
Okay, thanks so much Steve!
Has thanked: 634 times
Been thanked: 839 times
I've now pushed a change to the original Mega 2560 definition file to make it in line with the R3 version.
The none R3 version always had programming issues anyway and so the newer R3 should be much more common and it makes sense to head off this type of problem in future.
