If I create a 100ms flasher.
Then both delays are changed to 1 second.
If I change my mind and use undo icon or ctrl z
Each delay is then highlighted but visually remains at 1 second.
However if delays are double clicked on you can see they have reverted back to 100ms.
If then ok is selected you can see that they are set to 100ms.
Refresh screen issue?
Undo visual issue
- Has thanked: 794 times
- Been thanked: 853 times
- Has thanked: 311 times
- Been thanked: 479 times
