Undo visual issue
Has thanked: 794 times
Been thanked: 853 times
Flowcode v11 Undo visual issue
If I create a 100ms flasher.
Then both delays are changed to 1 second.
If I change my mind and use undo icon or ctrl z
Each delay is then highlighted but visually remains at 1 second.
However if delays are double clicked on you can see they have reverted back to 100ms.
If then ok is selected you can see that they are set to 100ms.
Refresh screen issue?
Has thanked: 311 times
Been thanked: 479 times
Re: Undo visual issue
Thanks, Martin. I've sorted that for the next release.
