TouchScreen Dial Keypad
daddytims_tims
Has thanked: 126 times
Been thanked: 13 times
Flowcode v10 TouchScreen Dial Keypad
Post by daddytims_tims »
Good morning
I am having a small problem with, figuring out how can I get my keypad to dial 7-digit numbers then initialized a call
In my current program;
If I press "#" ALONE it sends off and makes a call
If I dial any 1 or up to 6-digit numbers, it sends off and makes a call
What I want is Only when I Reach 7 digits Then that's the time it should make a call.
Any Help? Please and thank you.
Esp32_KEYPAD.fcfx
(83.97 KiB) Downloaded 28 times
Has thanked: 177 times
Been thanked: 1026 times
Re: TouchScreen Dial Keypad
Post by mnfisher »
Assuming '#' is widget 12 - you have if widgetpressesd = 12 ... cmd = ATD876 + tmpstr.+ "\r\n" - which I'd guess does dial.
You perhaps want to add a check that tmpstr contains sufficient digits for a valid number (if (widgetpressed == 12) && (Length$(tempstr) == 7))) then dial...
or Length$(tempstr) >= 7 - to allow for longer strings - although you might want to truncate - or throw an error if tempstr has more than 7 digits?
daddytims_tims
Goodmorning.
Thanks for your help.
The first one works great for me..
I prefer for it to be exact 7 as i already have the area code inside the prgramm already...
So how do I set it to be. If greater than 7. Throw in an error ?
Post by mnfisher »
Glad it worked.
As to an error - depends how you want to handle it - for example you could ignore digits after 7 have been entered.
Or - better:
You could alert the user - display an error message (invalid phone number?) - similarly - if the user presses '#' before sufficient digits - display - "invalid number please enter 7 digits"
daddytims_tims
Thats awsome. I would prefer the second option.
How can I set that up?.
Post by mnfisher »
I'm not at a computer - but.
Something like:
Add a macro Dial(string number)
Then in your loop - if (widgetoressed ==12) Dial(tmpstr)
In Dial (number)
.len = LengthStr$(.number)
if(.len != 7) Message("Invalid number - please enter 7 digits)
else
.msg = "Dialling " + .number
Message(.msg)
.... do the call ATD....
Message("Hanging up")
etc
daddytims_tims
Good Morning
I just get the time yesterday to work back on this project.
Thanks again for your HELP
I have inserted the Macro as instructed, filling the information
I am still having difficulties in trying to solve the problem
When is reaches 7 number it doesn't branch to the "NO" SIDE
Is there a way to prevent 12 from displaying on the Screen when press "#" Only?
It also seems that I have TOO MANY variables working with inside the keypad area
What am I missing out on?
Any help would be appreciated
Old_ProjectKeyPad.fcfx
(86.63 KiB) Downloaded 6 times
Has thanked: 311 times
Been thanked: 479 times
If I understand your project code correctly, the change I would make is to change the code around "If WidgetPressed = 10" to a "Switch" statement with cases for "10", and "12" (which I assume is the '#').
The Default branch would do the code that's currently in the "no" of that decision (including the "if Widget = 11" decision). And the "10" branch would do the "yes" branch.
The "12" branch would do whatever should happen when "#" is pressed.
