The attached program is an attempt to talk to a LCD / Touchscreen with an UNO.
While it simutales OK, I am not getting any response after compiling to the target. I suspect that there are some parameters within the board properties that are incorerect.
Programming a TFT_LCD_ILI9341
Billduck
jgu1
- Has thanked: 839 times
- Been thanked: 205 times
Re: Programming a TFT_LCD_ILI9341
Hi Billduck!
I have had a look at your testprogram and dare to change a little
You have to set the settings for "solid and tranperrant" in settings.
Suppose the background is white and the color for the drawing is the same color you can´t see the line.
There are so many options to change all possible colors for background, foreground and transparency etc. in this display with FC9. Like me you have to try and try to get experience.
Really good display. Furthermore, if you use an ESP32 and SPI, Ben has speeded up the speed. lightning fast.
If you are interested I can share some of my test/play program.
Br Jorgen
Br Jorgen
- Tranp.PNG (4.45 KiB) Viewed 3572 times
- TFT_LCD_ILI9341.fcfx
- (11.08 KiB) Downloaded 355 times
Thanks for the look at.
I am very interested in the test/play program. Is that on the ESP32 and SPI?
By the way, for my application, I had to change to the MEGA, as with the UNO, there were no digital I/O pins availible.
jgu1
Hi Bilduck!
Hereby as promised some examble. The BME280 uden_firkant is a project I made with a BME280, RTC. As on the picture.
Hope this can help you a bit foreward
I spend lot of time with this display Working fine with Flowcode. And it is really fast with ESp32 SPI.
Sorry the picture is "up standing" turn your screen
Good luck
Jorgen
Good luck
Jorgen
- IMG_4142.JPG (48.1 KiB) Viewed 3547 times
- BME280Ili9341uden fir_ 18f46k22 Intern.fcfx
- (52.93 KiB) Downloaded 368 times
- ESP32 ILI9341 BR (1).fcfx
- (13.04 KiB) Downloaded 375 times
