WS2812B, PIC18F47Q10 not work error!(Solved)
seokgi
Has thanked: 8 times
Been thanked: 8 times
Post by seokgi »
I am trying to design a PCB using the WS2811 library because SK6812 is difficult to program. However, the WS2811 library does not compile. The program used examples from Wiki Help.
Sends a compiler error message.
Thank you.
PS.
Is there any plan to support library for SK6812-RGBW?
WS2811.fcfx
(8.65 KiB) Downloaded 761 times
Has thanked: 616 times
Been thanked: 814 times
Re: WS2811, PIC18F47Q10 Compile error!
Many thanks for letting us know, I have now fixed the compilation error.
As for the SK6812, this looks like it should be compatible with the current WS2811 component. It would just be a case of using the custom mode and getting the timings right.
seokgi
Post by seokgi »
Thank you for your kindness.
As seen in SK6812-RGBW, it has 4 colors and is a 32-bit command. Is this applicable to WS2811/12/12B?
seokgi
Post by seokgi »
Thank you for your help.
Compile works fine. However, the example program does not work. We will send you the oscilloscope screen for your reference.
I tested the external crystal and internal oscillator on PIC18F26K22, and PIC18F47Q10.
I used WS2812B.
I think the timing isn't right.
Help.
Thank you.
AnimLightStrip2 (1).fcfx
(12.63 KiB) Downloaded 680 times
seokgi
Re: WS2812B, PIC18F47Q10 not work error!
Post by seokgi »
I tried to run it at 32MHz using an external crystal in PIC16F1937, but it doesn't work.
seokgi
Re: WS2812B, PIC18F47Q10 not work error!(Solved)
Post by seokgi »
I use WS2812b.
I solved it by correcting the time in Custom in the library.
I upload the program I solved.
Be sure to check the timing using an oscilloscope.
SK6812 seems to be difficult for 8-bit PIC. It seems possible on a 16-bit PIC with a higher clock speed.
Thank you.
WS2812B_PIC18F47Q10.fcfx
(19.26 KiB) Downloaded 811 times
