PIC16F684 Timer Problem FC8 FC9
Vatel20
The Interruption probably occurs in each clock cycle.
- TestTimer.fcfx
- (14.62 KiB) Downloaded 511 times
- Has thanked: 615 times
- Been thanked: 812 times
Re: PIC16F684 Timer Problem FC8 FC9
Please can you explain what problem you're having?
In the Left column are the minutes and it goes faster than the seconds. The INT routine is executed more than 61 times per second. Thank you.
- Has thanked: 718 times
- Been thanked: 778 times
Hi Vatel20,
Simulation is not accurate when compared to real-time.
It is normally much faster than real hardware, so it's a known issue.
Do you have the same issue with hardware?
