PIC16F684 Timer Problem FC8 FC9
Vatel20
The Interruption probably occurs in each clock cycle.
- TestTimer.fcfx
- (14.62 KiB) Downloaded 530 times
- (view online)
- Has thanked: 647 times
- Been thanked: 856 times
Re: PIC16F684 Timer Problem FC8 FC9
In the Left column are the minutes and it goes faster than the seconds. The INT routine is executed more than 61 times per second. Thank you.
- Has thanked: 794 times
- Been thanked: 853 times
Hi Vatel20,
Simulation is not accurate when compared to real-time.
It is normally much faster than real hardware, so it's a known issue.
Do you have the same issue with hardware?
