Automatic Com port Select
Has thanked: 292 times
Been thanked: 458 times
Re: Automatic Com port Select
Hi Oscar,
I've looked into this and created another DLL. Can you please try it and see if it allows detection of your FTDI device?
The DLL is in the attached ZIP file. It needs to replace the existing SerialDLL.dll file that is in Flowcode's Data\API.DLL folder.
Please let me know if this works for you.
Thanks,
Steve.
SerialDLL.zip
(105.61 KiB) Downloaded 758 times
Oscar_T
Has thanked: 37 times
Been thanked: 10 times
Post by Oscar_T »
Hi Steve
i did a test very quickly and it seems to work! Fantastic really appreciated!
Kind Regards
That's great news! Thanks for the quick response.
Has thanked: 234 times
Been thanked: 252 times
Hi Oscar, Hi Ben, Hi Steve
I like to use this auto comport too. But when I use the program from Ben, it don't shows me a port, even I have some.
What do I wrong?
Oscar_T
Post by Oscar_T »
Hello Stefan
Which com port are you trying to open? the number 40?
Have you modified the VID/PID?
Hi Oscar
Yes
Oscar_T
Post by Oscar_T »
Is a FTDI Device?
I have tried several units (always with the same vid / pid) and they are recognized and numbered correctly.
I also tried to run the program on different computers and for now all fine.
Have you installed the official ftdi drivers? Have you installed the new dll?
Excuse me if these seem trivial questions to you but sometimes the problem is just a simple thing
Yes driver is new and the VID and PID look like the same value.
Dll is copied.
Oscar_T
Post by Oscar_T »
And if you go to the windows registry you find the same thing?
Hi Oscar
Thanks a lot for your help. It's working now. The problem was the dll.
I copied it to an "old " folder with an old FC9.
So this autodedect comport is really a good thing.
