PIC32 I2C is not working after update PIC32BIT_CAL_I2C to v5
Has thanked: 246 times
Been thanked: 258 times
Hi Steve
On my board with a PIC32MZ2048EFG100
after the update PIC32BIT_CAL_I2C.C from v4 to v5 the RTC is not longer working. The time and day is 000000
If I go back to v4 the real time clock is working again.
Re: PIC32 I2C is not working after update PIC32BIT_CAL_I2C to v5
Can you have a look, why the update from 4 to 5 for PIC32BIT_CAL_I2C.c is not working correct.
after the update PIC32BIT_CAL_I2C.C from v4 to v5 the RTC component is not longer working. The time and day reading is always 000000
Has thanked: 647 times
Been thanked: 856 times
Hi Stefan,
Thanks for letting us know I am investigating this now for you.
I beleive I have found the source of the problem now and I've released an update via the update system that will hopefully fix the issue.
With the version 6 the program is "hanging" on the part with I2C
I've tried V4 and V6 several times.
