MCP3561/2/4 MCP3564 Click Board
Has thanked: 629 times
Been thanked: 836 times
Re: MCP3561/2/4 MCP3564 Click Board
BenR wrote:
Fri Jul 23, 2021 12:29 pm
I've now created a component for you and tried to keep it as simple as possible with just an initialise and sample macros. It may be too simple and you may want some of the more advanced features of the device, if this is the case then let us know the specifics of what you need. I can also share the component source project if you want to be more in control of what's available.
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Post by SpeedPIC32 »
Hello ok
I can try to get something done.
Please send.
With kind regards
Here's the source at the moment. I'll do some more investigation and see if I can pin point why you're having the current issues with it.
ExternalADC_MCP356X.fcfx
(49.9 KiB) Downloaded 1243 times
SpeedPIC32
Yes ok that's good thank you.
SpeedPIC32
Hello BenR
I can't get the error to go away.
Please look at it again.
Are you still able to send us a module for testing? I've tryied to get my hands on one a few times but can't seem to find an easy source for them.
SpeedPIC32
Yes I am sending a board.
I need your delivery address
Has thanked: 245 times
Been thanked: 256 times
Hi Ben, Hi SpeedPIC32
I'm evaluate a also new ad converter for one of my project.
I was looking for the
ADS112C04 16 bit 2ksps I2C bus
ADS122C04 24 bit 2ksps I2C bus
But I'll also have a look at the MCP3564 and I will order a microe board from farnell
https://ch.farnell.com/mikroelektronika ... dp/3528567
SpeedPIC32
I have already packed the board and only need the address. :D
Excellent thanks very much.
Address is
Ben Rowland
MatrixTsl
The Factory
33 Gibbet Street
Halifax
HX1 5BA
UK
