LTSR 15
jgu1
Has thanked: 910 times
Been thanked: 220 times
LTSR 15
Post by jgu1 »
Hi Martin!
I will not hijack in FC8 forum concerning the above, thats why I ask here.
I have tested your new component. Seemed to work nicely, but sometime fluativatin a little, and as I see the Ref on the LTSR is sensitive. Do you know what I should do with this pin, ground or? pls.
I remember you for a short while ago edit the I2C display so it is possible to set how many decimal we want in a Float. Work nice in real world but not in simulation. Small thing :lol:
Jorgen
Ltsr.fcfx
(9.46 KiB) Downloaded 971 times
Has thanked: 795 times
Been thanked: 858 times
Re: LTSR 15
Hi, Jorgen,
The REF is a 2.5V bandgap ref output, so you can leave it open circuit.
I believe its function is to supply VRef of a microcontroller to make the results even more accurate (and more stable in the case of PSU ripple).
Thank for the spot with the simulation, I Will investigate and fix the issue of the decimal places issue.
Edit:
If you roll back one version, then the rounding will work again.
I will still investigate the cause.
jgu1
Re: LTSR 15
Post by jgu1 »
Hi again Martin!
Thank´s for reply and info. The first test I perform, was a quick test. Tomorrow I do some more test and you hear. :D
Jorgen
Re: LTSR 15
Hi Jorgen,
I have fixed the issue.
If you run an update, the latest version I2C LCD should work for you.
jgu1
Re: LTSR 15
Post by jgu1 »
Hi Martin!
Thank´s for great job.
Display in simulation, perfect ;)
I make some test. Look good.
Powersupply in serie with my fluke and the LTSR15
Fluke A mp. ** Ltsr. Amp.
0.00 >> >> >>>> 0,00
0,50 >> >> >> >> 0, 49
1,00 >> >>>> >> 1,21
1,5 >> >>>> >> 1,45
2,0 >> >>>> >> 1,93
2,5 >> >> >> >> 2,65
3,0 >> >>>> >> 3,13
3,5 >>>>>> >> 3,37
4,0 >> >> >> >> 3,85
4,5 >> >>>> >> 4,33
5,0 >> >> >> >> 4,81
all in all when we take into account that it is a component with such a large measuring range and that resolution is I thought it is very fine. And the small inaccuracies could be hardware as well as I can see the stability of supply voltage must be very very stable.
I have not test and compare in datasheet, but could the component also be used with ASC712? :D
Br Jorgen
Re: LTSR 15
Thanks, Jorgen, that's not bad at all, considering the maximum current for the LTSR 15 is +/-48A
jgu1 wrote: ↑
Wed Sep 01, 2021 7:21 pm
No, but the good news is Flowcode already has an ASC712 component.
Just select Component Libraries, then select the search magnifying glass and enter acs.
You can select the version from within the properties.
jgu1
Re: LTSR 15
Post by jgu1 »
Hi again.
I dont think so ;) Can´t find it, either in FC8
I think you are thinking of this thread that was apparently never made a component for ACS7xx, but would be nice ;)
https://www.flowcode.co.uk/mmforums/vie ... acs#p98662
Jorgen.
kersing
Has thanked: 81 times
Been thanked: 65 times
Re: LTSR 15
Post by kersing »
ASC vs ACS?
Re: LTSR 15
jgu1 wrote: ↑
Wed Sep 01, 2021 8:52 pm
I dont think so Can´t find it, either in FC8
Ah, sorry you are right, it's my mistake
Leave it with me and I will get something sorted out for you.
You will have an ACS712, by end of tomorrow.
Re: LTSR 15
kersing wrote: ↑
Wed Sep 01, 2021 8:59 pm
ASC vs ACS?
Sorry that was a typo, ACS is correct.
I even entered acs after. ;)
